The Plc Kid
I am trying to select a new power supply for a small devicenet network 10 nodes and it currently has a standard open frame power supply and we are having lots of problem dropping nodes.
This is not a devicenet rated power supply so i am almost 100% sure it is the culprit.
What makes a power supply devicenet rated? Is it the noise control /immunity?
Or is it more about the tighter voltage regulation or both?
I am trying to select between these http://www.clrwtr.com/PDF/Sola-Hevi-Duty/Sola-SDN-DeviceNet-Power-Supplies.pdf
I can not find any info on the power supply we have now so i do not know it's output rating.
Is there any harm in using the higher output supply on the network?
Price not being a factor i would just buy a devicenet rated/certified ps with the highest output rating i can find and be done with it. Any issues with this approach?
This is my first stab at devicenet and i want to cure these problems fast.
This is an all ab system with flex i/o and 1336 drives a slc 5/04 and 1747-SDN version 3.03 firmware.
