TIA Portal V13 FB for WAGO 750-637 Encoder
Scarra
Oct 2016
Tilburg
Hi Guys,
I would really appreciate your help here: Does anyone have a Siemens TIA Portal FB for the WAGO 750-637 32-bit encoder? If I had the time I would surely try decipher it myself, but unfortunately that luxury does not exist here and it's wasteful inventing the wheel again.
Many thanks in advance
I assume you're using a 1200/1500?
If it is a PN encoder, create it as a technology object (TO_External_Encoder). You would need to use telegram 81 or 83. I'm a big fan of the MC instructions. The PLC handles the interface, and the generic blocks handle all the control.
Thanks mk42.
It's a WAGO Incremental Encoder Interface 32 Bit / differential / single interpretation. I tried using the TO_ExternalEncoder, but it does not recognize the technology module (address) as I configured it from the GSD file.
Nevermind, you're right. The modules support PN but do not appear to support profidrive.
Scratch my idea.
I am working on a program that was developed in 2015 for an S7-300 safety PLC. The new copy of this machine uses an S7-1500 safety plc. We were...
1,839
Hi Guys, Please, I'm in need of TIA Portal v13 SP1 The V13 I saw can't open a Comfort panel HMI file. Can any one help? It will be much...
5,341
TIA Portal V13 with 1515 Processor. TIA Portal being run on VM. For many weeks, was able to go online and monitor blocks while troubleshooting...
3,947
We had hard drive failure and lost our most recent backup of one of our TIA Portal V13 projects. I uploaded the current program from the PLC...
4,142
Hi, I try almost everything but not solve the problem. As attached is the screenshot of the error from Tia Portal, There seem problem with the...
4,035
