Encoder - Paralel wiring
shanimi
Mar 2004
Hallo to everyone
Is it possible to wire one encoder to two High Speed Counters?
one HSC is connected to an old machine while the second HSC will be connected to a new PLC - collecting data
Shanimi
Hey
U mean, u have an A signal and a B signal. The B signal is 90 degrees later for detection of countdirection. And u just want to use the B signal for your PLC and the A signal to your old machine...
As long as the potential is the same...
Your encoder outputs would at least need to be line driver type. You can get boards from several mfgrs that allow you to use 1 encoder and it gives 2 to 4 outputs. This would be the better solution.
What is a line driver?
This is an old machine that I am afraid to touch
I can only connect paralel to the signals from the encoder
Is this posible?
Shanimi
To even start to answer something like that you would need to know:
1. The model (including output type) of the encoder
2. The model of each HSC.
3. The method of wiring to the present HSC.
Cosiderations are:
1. Isolation between the present system and the proposed system.
2. The drive capability of the encoder - can it take another load without degrading the signal.
A simplistic answer would be - sure, hook it up and see if any smoke comes out.
Absolutely mysterious declaration.
Why open-collector is out of the game?
Answering the main question- yes, it is possible if both HSC have matching input types.
And most probably you will need to connect logic ground (commmon) of both machines.
By the way, our OEM company often integrates third-party laser and ink pinters into our packaging machines.These printers need encoder pulsetrain for printing. We never try to split our machine encoder signals but put independent encoder for the printer. Overall we win on design and troubleshooting time.
If the excisting encoder is a 24V line driver type, then you can easily connect both PLC inputs (old & new PLC) in parallel.
If it's an open collector (NPN or pull down) output type, I would suggest using diodes in series with every PLC input, since voltage levels between old & new PLC's might be different.
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
232
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
952
Dears, i am trying to change the series of encoder from A to B, but the program do not has this option (Rslogix5000, 20.06 the old encoder was...
199
Hi all, I am working with an incremental encoder (ABZ signals, 360 ppr (so 1440 counts per rev)) to replace the existing "manual" encoder wheel I...
51
2,544
Hi all, I am implementing an incremental encoder sensor (ABZ) to replace the existing "manual" encoder wheel I have in my device. This is a 360...
160
