Legacy AEG PLC
shakaljack
Sep 2011
Warsaw
Hello,
I have found very old AEG controller from AEG type PSE 802.
Does anyone know how to get program from PLC ?
Thank you in davance
Pse 802.
Hello ,
PSE 802. is avery old controller made by AEG team.
It can handle very easy logic such as and or maybe something else.
I am not sure if it has timers and counters.
I found instalation with only digital Inputs and digital outputs ( 24 VDC )
CPU iis programmed using microcontroller.
First you compile and download program to microchip and then you place microchip inside CPU
Regards
hello,
we are using one of these controllers, and i am surching for spare parts.
do you have some? or someone else on this forum?
regards,
of course, thats why i'am on this forum. :ROFLMAO:
I hope that someone can help me with spare-parts or a controller they don't use any more witch i can buy or swap for example a S5 siemens.
anyone????
I'm using legacy recipe to download a recipe to the PLC. A little background, the recipes are large. They are broken down into 6 tables, each 16...
106
We have a keg check weigher that that lost a fight to a forklift. The scale was previously a Systec IT3000, which was the only PROFIBUS slave...
671
OK, I thought I saved a few bucks buying a "new-open box" cable and it's the old version and SE doesn't support it, no driver available. Anybody...
1,481
I had another legacy HMI replacement fall in my lap. A good customer of mine lost the program out of an old PanelView 600 (I'll attach some...
2,039
Hi, im looking to migrate a 2711-K10C10 to a 2711P-T12W21 Panelview Plus 7 Standard. I migrate the PV1000 application .pba file in FactoryTalk...
1,962
