Topics in RSLinx: Question about accidental deletions
Russ
Jun 2002
Ohio.. Go Bucks!!!!
261
I accidentally deleted a topic in linx and when I went to recreate it Linx wouldn't let me use the same name. It kept popping up 'This topic name exists or is invalid! Even though the name was no longer on the list I couldn't create a new topic with an identical name to another topic. I was getting this even though the original topic had been deleted.
I had to rename a topic in the registry in order to get this it to work properly.
Is there an easier way to do this, just in case it happens again? I can now fix this in just a couple of minutes. But finding out how to do it took about an hour.
Other people might be in the same boat that I was in and might not be comfortable with registries..
Hi there, I have little annoying problem with configuring Alias Topics in RSLinx Classic Gateway. I created two drivers for each PLC in redundant...
2,629
Hi there, I got a little huge problem with the redundancy concept of AB. My network consists of 24 CLX61 controllers, each one redundant (twins...
4,486
RSLinx Classic Gateway 2.57.00.14 Windows Server 2003 R2 OPC Test Client Visual Fox Pro applications using OPC I have an issue where the RSLinx...
2,482
Just curious... There was a topic going last week on VPNs. I found it informative and relevant...
3,796
Can someone provide a definition of topics in RSLinx? Seems this is a "path" to a controller form which data will be gathered? Thanks, Burch
1,539
