KepDirect Server would no communicate with an USB converter.
piscis
May 2003
241
Has anyone had this problem? I move the same ladder file, same OPC file to a desktop computer with an RS232 port and everything works just fine, and I’m able to see the variable and outputs moving with both, KepDirect Server and DirectSoft32.
If I tried to do the same with my laptop using an RS232 USB converter then nothing happens I get a Bad (Out of Service) message with OPC Quick client, I tried two USB converters, the one from AD and another from Radio Shack, no luck.
My laptop is brand new; I do have good communication with DirectSoft32 using the same port and with both USB converters.
Anyone have a clue?
Andy
Not an uncommon experience, when one software package works with a USB converter and others don't.
I've had the worst experience with a Belkin converter.
I've had the best experience with a Saelig USB-COM-S converter.
http://www.saelig.com/miva/merchant.mvc?Screen=PROD&Product_Code=U004&Category_Code=
I'm not sure any one converter works with all software.
I seem to recall comments from others on this forumn that some of the PLC mfgrs. recommend certain brands/models.
My suggestion is to try another brand/model.
The Saelig sell for about $25 USD each and they seem to have a technical involvement with USB that's deeper than some of the asian import converters seem to.
Dan
That is a bit odd Andy, we have tested the USB-RS232 to work with all of our software. With the exception of our older DirectTouch programming package which has been discontinued the USB-RS232 does work with all of our software.
I really don't know offhand what might be the problem, but you might need to update the OPC server software to the latest build. You can find it here.
I downloaded the demo software and install it on my desktop and my laptop computer. I built a small Quick Client with four Data words and five...
7,528
Hi, we have a Wonderware InTouch 9.x setup which is reading some tags from a KEPDirect server. I just added a new floating point tag to...
6,273
HI I am trying to have a vision software communicate with PLC DL205 through the ECOM. but i found that Netedit (ECOM) itself cannot communicate...
3,716
If anyone has a crack for IBH OPC Server, please send it to: [email protected] Urgently. Thanks in advance!
58
Folks, I have a client with an old ABB Advant / MOD300 system (v14.4). Around y2k I installed the ABB Industrial IT MOD300 OPC Server 1.1/2...
65
