parky Member P Join Date Oct 2004 Location Midlands Posts 5,744 May 23, 2020 #16 Yes the above is correct, I have done one using S5 version timers in S7 so it looks similar to RW However, you will notice I have used M0.2 as a latch to emulate the TON.EN bit Last edited: May 23, 2020
marvis Member OP M Join Date Mar 2016 Location Italy Posts 108 May 23, 2020 #17 In accord with your suggest I think now should be ok, but I can test only monday morning! What do you think? Thanks.
marvis Member OP M Join Date Mar 2016 Location Italy Posts 108 May 23, 2020 #18 Thanks for your support. Have a nice weekend.
L D[AR2P#0.0] Lifetime Supporting Member L Join Date Nov 2006 Location UK Posts 6,694 May 23, 2020 #19 Read the help on the TON block - specifically the IN parameter.
marvis Member OP M Join Date Mar 2016 Location Italy Posts 108 May 23, 2020 #20 L D[AR2 said: Read the help on the TON block - specifically the IN parameter. Click to expand... Thanks!
