by spec i must supply surge protection for each individual PLC input in my panel. These devices are all of the voltage free (dry contact type) where the 120VAC will be supplied by my panel. i found a WAGO MOV to ground terminal block and i believe this is the appropriate device to comply with the spec and protect my PLC input card from voltage transients. Has anyone used these devices before? Thanks for any help.
