RSLogix5000 License
agdacanay77
Apr 2007
Philippines
36
To All Gurus,
I have RSLogix 5000Ver.14 , 16, 17, & 19 with license. If i updated to version 20 does the existing license will support version 20?
Thanks and Best Regards,
Allan
Yes. Your existing RSLogix 5000 license will allow you to download the same Edition at version 20 from their website...
SOFTWARE DOWNLOADS
Go to "Software Downloads by Serial Number".
You must have the current product serial number and the Company name registered against it to validate and proceed to the downloads section.
Regards,
George
Hi
It will but from memory ver 21 up will not as I think the license was changed then. If your license is in support it will work up to the current version 26
Donnchadh
You did not indicate what type / series of license you have.
It it the old EVMove system, it will not work past version 19.
If you are using FactoryTalk Activation it will.
If it is the older type then Rockwell will assist you in migrating it to FactoryTalk Activation.
Hi
Donnchadh
The license is valid for all versions. But there are hardware limitations to using v21+. For ControlLogix firmware v21+ requires an L7x processor and only newer CompactLogix are compatible.
Anyone know the procedure and steps to take with Rockwell when an employee quit but never returned his work laptop and has the Rslogix5000...
1,665
Hello guys I'm looking for help with this little problem. I have a laptop with licenses for RsLogix5000, Factory Talk View Studio, Rs Networx...
1,971
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
112
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
427
Hello everyone, I have an RSLogix5000 project which is running live in the factory but I need to make some changes to the logic. I want to test...
1,120
