FactoryTalk View SE (6.1) Dynamically Sort a "List" of Objects
KristienP
Jan 2015
Nova Scotia
44
I'm looking to create a "List" of remote sites, that will automatically sort itself from Least to Greatest, based on an analog tag from each site. Each site (12 total) has a Time to Empty value calculated in its PLC (mix of Micro & Compact Logix), which is read back to FTView along with other site data.
The client has asked to have a list that sorts itself based on Time to Empty, along with Yellow / Orange indicators based on the amount of time remaining.
I was planning to create a Global Object for each site, which would show the site details and change color (Yellow / Orange) based on the time remaining. But I have no idea how to dynamically sort this list!
I was thinking I could create an expression in Animation --> Vertical Position for each Global Object, after it's drawn on the page, that would compare each sites Time to Empty, but that seems like it would get complicated in a hurry.
Does anyone know of an easier way to dynamically sort a ground of objects based on different analog values?
Hi, I wanted to ask is there a way to have a visibility expression use the IP address of the HMI (Dynics, not PV) to show certain elements? The...
166
This is admittedly a pretty obscure problem, but maybe someone else has run into it, or at least something similar. For reasons I won't get into...
103
Hey everyone and anyone that can lend a helping hand. I have a project that I am being asked to add some animations of Solidworks or "3D" models...
299
I can't seem to get the Panel View Plus 7 standard edition to downgrade to V_11, when I check the AB downloads and compatibility websites for this...
122
Hi, I'm trying to export data from a DataGrid to Excel using VBA, but I'm getting an error "Object doesn't support this property or method". The...
71
