DNP3 SCADA & Allen Bradley Controllogix PLC Integration
Ariel Danez
Sep 2005
Dubai
I have an Allen Bradley Controllogix PLC with a CLX Ethernet/IP 10/100 Bridge Module-Twisted. It was originally designed purely for Data Acquisition and shall be integrated to a SCADA System using Ethernet Protocol thru a Hirchsmann Fiber Optic Switch. Plan was changed and we have to integrate it now to an SCADA System using a DNP3 Protocol. We dont have any experience in this type of protocol. Should I need an extra Gateway in between my AB CLX Ethernet/IP Module and the DNP3 based SCADA Sytem ? Any System Integrator I can contact with specifically
If you use a gateway, you lose DNP 3 functionality at the gateway. There are several imbedded commands such as pulse accumulation and freeze commands that do not translate well via a gateway. If you want to keep this functionality, custom coding the communications directly in the PLC.
The problem with DNP is that it is a standard protocol that historically gets changed for each customer.
Dear Experts, Thanks in advance for your kind help. I have a GEO SCADA expert 2022 and configure it as a DNP3 master, also I have multiple DNP3...
601
We are trying to add a new device (Fuse Saver) to our iFIX SCADA System through DNP3 protocol. As you know every DNP3 device comes with a DNP3...
3,380
Hi all, happy new year! I read a topic lately and many more before that where a lot of people saying that Ignition is damn good SCADA, so I...
333
Dear Experts, I have a system which contains 10 PLCs (1214C CPU) each PLC with DNP3 module CP1243-1 ( 6GK7243-1BX30-0XE0) and with GSM module and...
345
I have pi osisoft DNP3 icu communicating with a SEL RTAC. I am receiving multiple messages from the rtac on each register. With analog tags...
685
