LOGO! 8 up/down counter
Levi G
Sep 2015
Alberta
148
I am using LOGO Soft Comfort V8.1
I am trying to reset a UP/Down Counter when it reaches a certain value but I can not find the way to do it, does anyone know of a way to do this?o_O
I am trying to accomplish this in FBD Editor.
That doesn't do quite what I had in mind, I would like to turn an output on when the counter reaches a certain value, for example 10, then at 11 I would like to reset the counter.
Is there a function that I am missing like a COMPARE Function(Equal, Greater Than, Less Than, or Not Equal.) or something similar?
I've never used a compare function with the logo the best I can come up with is this, the output counter is set to 10 & the reset counter is set to 11
Steve
Steve
Well that will work, why didn't I think of that.
Thanks for the help:site:
Hello Team, I am desperate for some help with an assessment I have as part of a Level 3 general engineering course. I am in a role that is much...
337
Hi all, First, thank you for reading the thread. So I had a task as the following: An up-counter must be programmed as part of a batch-counting...
274
Hi Lads, I want to implement a flood prevention system with my domestic water pump. The intention is to have the water pump cut off on a daily...
1,055
[Update: fixed a typo in the image.] See the image below, especially the blue-ish annotations. The three rungs ending in output coils -( ) are...
17
960
We need a Really Simple and Cheap controller that has a display or a Web Interface where we can change some set points. We were thinking about a...
1,025
