Safety Interlock PLC – Adding New NonSafety I/O
phasors
Jan 2012
Newark
A client is the need to add new I/O points to SCADA. The most affordable solution is to wire these new points to an existing safety interlock PLC. If these points are wired to the PLC, would a code violation of any kind occur? Would the integrity of the safety integrity system be preserved?
Thanks!
Does your facility allow anyone to bypass door safety interlocks? I am against this but there's a discussion again at our plant about needing to...
2,517
If I have a cell where the doors are monitored with a sufficient level of guarding, is it required to run the locking signal to the door on a...
1,333
Hi can any one explain me how this interlock ckt works with 24 volt
2,815
I have a customer using a tongue-operated interlock switch, directly connected to the safety inputs (SC, S1, S2) on an FR-D720 Mitsubishi inverter...
7,198
I have a similar application, but mine is in a hazardous location. Thus far I'm coming up empty for solutions. The client would like to lock some...
8,064
