PC to SLC 5/04 Din connector programming port cable needed
cyclingtom
Nov 2010
Indianapolis
Does anyone know the correct AB cable I need to connect a laptop serial port to an SLC 5/04 processor programming port, specifically the DIN connector? Seems to be some confusion between our distributor and Rockwell on the correct cable.
The DH+ din port? For that you need a PCMK card and PCM/5 cable with CP7 adaptor (or PCM/6 cable). Alternativly you could use the USB version.
EDIT: I think the part numbers are correct?
What part numbers have they given you? There are several options...
Do you plan to communicate with it via DH+ or serial?
The Mini DIN Connector is for the DH+ Port, and will allow you to program that PLC, and any other PLCs visible on the DH+ Network. However, you need a DH+ Communications Card or Adapter to do that.
I have never seen a direct cable to the DIN Connector, there is usually a DB9 to DIN Adapter. These used to be included with the PLC5 Processors along with the Terminating Resisitors etc.
Someone may make them aftermarket though.
Stu....
The 1784-PCMK card, as mentioned, has two different cables for connection to DH+ networks; the 1784-PCM5 connects to Classic PLC-5 controllers, and can use a 1784-CP7 "Space Shuttle" adapter to connect to the Mini-DIN8 connector that is on Enhanced PLC-5 and SLC-504 and 1756-DHRIO modules.
The 1784-PCM6 cable has a Mini-DIN8 directly on it.
All of this is historical information, though; the 1784-PCMK quietly stopped production almost two years ago. Be aware also if you're buying used equipment that the Series A and Series B cards and cables must match Series letters because the card-to-cable connector is different.
Rockwell Automation offers a modern DH+ interface, the 1784-U2DHP, which connects from USB to Data Highway Plus and has only the Mini-DIN8 connector on the end. A "reverse adapter" is available from Grace Engineering if you need to connect to Classic controllers or very old DH+ networks.
Third party DH+ bridges and adapters are available on the market. RA distributors do not sell them nor will RA support them.
hi all
i have slc500 cat-1747-L541,, can some one help how i interface my rslinx with cpu and then upload programme from cpu,,
i am using serial cable for communication,, which driver i should select from rslinix confiqure drivers to interface and steps to follow as well,,
thanks in adavace for ur consideration
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
81
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs...
95
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
103
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
96
Hello, I have a ControlLogix redundant controller being set up. The program reads a value from a remote site which hosts a SLC PLC. Rockwell...
78
