AB 1794 Flex IO
DaveW
Apr 2005
SoCal
389
Does anyone know if the electronics for the Flex I/O modules are internally powered from the backplane or do you have to power up the terminal block base? I have some 1794-OW8, 1794-IB16 and 1794-OB16 connected to a 1794-ASB with 24VDC on the ASB that I want to configure and setup with the PLC but without powering up the I/O's until they finish wiring all the field signals first.
Those ones are. The 24 VDC supply to the adapter module will power the "brains" of up to 8 discrete modules attached to the FlexBus plug.
Most analog modules require a separate power source, preferably one that can start up simultaneously or before the adapter does, so the adapter can properly determine how many modules are connected when it boots.
For the discrete modules you mentioned, you can go ahead and just connect 24 VDC to the 1794-ASB adapter module.
Apparently I did not read initial post completely:
For setup purposes you don't have to have any power to the base, "brain" will work from the bus. But to control someting you must have 24VDC connected to the output bases.
Sorry for confusion.
Hi all, what is the proper way to fuse 1794-IE12 modules? fuse sizes/locations? We are burning up these modules in our facility.
1,721
Does anyone have any insite to when the 1794 Flex io will go active mature? Just not ready to switch to the new flex 5000. We use flex for remote...
1,605
Hey guys, Im currently using the above flex IO to turn on two outputs these outputs go to two flashing red beacon lights. Here's the scenario: My...
1,706
Anybody can help me. I already read document in software rslogix 5000 and I think i can use software rslogix 5000 calibrate for flex module...
1,735
This is going to be long winded just because i am going to try and provide as much info as possible. Over the last month i have had the...
2,405
