What protocol for sending alarm from PLC->PC through rs & intelligent radiomodem?
WWalker
Jan 2006
Gdansk
I have to build communication channel between 6 PLC and 1 PC Workstation. Medium are "intelligent" radio modems with RS232/485 ports.
I've initially thought about using Modbus as communication protocol but as far as I know with that protocol I can't initiate connection from RTU (PLC) side and inform master station (PC) about fire or security alarm. Instead of with Modbus I must frequently send requests from PC to each PLC and check replies. Am I right? I don't like such scenario.
On the other hand I'm obliged to communicate between PLC and I/O modules through DeviceNet.
I'm in trouble:
What PLC supports both DeviceNet and any other protocol, suitable for radio communication channel, which could initiate message roundtrip from both sides (RTU&PC)? What is such suitable protocol? What should be configuration of radio modem transmission to avoid conflicts in a case two RTU at exactly the same time try send alarm to PC (rather impossible with fire alarms but possible with power-down alarms)
Thanks in advance,
WWalker
[email protected]
Hi all, My requirement is to send out escape character ( and also enter , line feed characters)from MicroLogix serial port configured in ASCII...
7,536
Hi all Trying to remotely connect to a TIA Portal PLC. I can ping it without a problem but can't get my software to connect. I've opened port...
326
I’m working on getting a Parallel Redundancy Protocol PRP system set up in a lab situation. The L73 PLC is in rack 4. 3 io racks are 1,2,3. I...
752
Does anyone have information or documentation regarding the protocol used in Rockwell's Remote IO, and how the physical layer of the network...
929
Hi everyone, I've got to interface 4 x Mitsubishi Q series PLC's with an Allen Bradley Compact Logix PLC using a Red Lion Data Station DSPLE000...
505
