Panelview 900 to Panelview 1000
sgates
May 2007
Utah
17
Can the panelview 900 full touch screen be converted to a panelview 1000 by changing the type of panelview using panelbuilder
Yes.
Just change the PV type in application manager, and let it go crazy attempting to re-validate.
Everything should be OK.
I have done several of these....Make sure that your communications are setup correctly.
Thanks, I thought it would work, but I wanted to ask someone who has done it befor I ripe the old one out and replace it.
Always get the new PV, dump the program in and make sure that it completes the validation process before RIPPING out the old!
You can always power it up remotely and plug in your comms as required....before you rip out the old.
Just from experience....
But you shouldn't have to worry about anything.
The 900 was discontinued in 2001, and so is the 1000 now I believe.
The Rockwell group wants to migrate you to the new PV+ as soon as possible.
Don't do it unless you have to.
Hi, I'm trying to figure out how to properly update the "icons" on my Panelview 900 (AB 2711-T9C9). I think maybe I'm having a fundamental...
993
Panelview 900 communicates with SLC 5/03 PLC. When I upload the program from the panel, some buttons have the address B3/306, B3/304 etc. However...
2,435
Panelview Part #: 2711-K9A8, that communicates via DH+ to a SLC504. There are two PV's on the network. One has lost its application. Downloaded...
1,960
A question for the hive mind, i have a Panelview 900, monochrome non touchscreen model. On power up, i get error 34 which relates to an extended...
2,162
I have those old early 90's panel views in my plant. I use an old XP image to get the program back into them but maintenance wanted a way to do it...
2,381
