FactoryTalk View SE and ODBC
Ok, I got it working. I forgot that I had to do a couple things. I had to add the odbc data source to the computer running rslinx and the computer running the hmi server. And then I forgot that I needed to do DataLogOn and DataLogOff.
Hi, i got the same problem under Windows 10 64 bit.
Thanks to Rockwell Support i could find a solution.
The solution for me was:
- Install/open the SQL Server managenment Studio
- Right click Security/Logins "New Login"
- Search "LOCAL SERVICE" and then ok
- Search "SERVICE" and then ok
For the new Logins "NT AUTHORITY\LOCAL SERVICE" and NT AUTHORITY\SERVICE
assing the Server roles "sysadmin"
Now it should work.
The explanation why you have "Test completet sucessfully" when you do "Test Data source", but it doesnt work in FactoryTalk View is that
when you test you connect to the database as local user, but when FTV tries to connect it does it as a service.
Thank you very much, crawler009! This works for me!!! 🍻
Now it should work.
Hello Rdrast!
I am facing the same problem as the one you posted the answer to. Unfortunately I didn't really understand the last bit of your explanation.
So, once you create the Logins 'SERVICE LOCAL' and 'SERVICE', what exactly do I need to put in FTView login? I would say I've tried every possible combination but the right one.
Thank you, Josep.
Hi Josep
in FTV you dont have to to anything. With this way you can leave the "Login requiered" unchecked, because the service has enogh rights to write to the database.
if you mean
this is done also in the SQL Server managment studio.
Edit: dont forget to restart the pc if it wont connect. FTV likes restart :)
Now it should work.
Worked and resolved the problem.
Thanks.
Hi, I wanted to ask is there a way to have a visibility expression use the IP address of the HMI (Dynics, not PV) to show certain elements? The...
166
This is admittedly a pretty obscure problem, but maybe someone else has run into it, or at least something similar. For reasons I won't get into...
103
Hey everyone and anyone that can lend a helping hand. I have a project that I am being asked to add some animations of Solidworks or "3D" models...
299
I can't seem to get the Panel View Plus 7 standard edition to downgrade to V_11, when I check the AB downloads and compatibility websites for this...
122
Hi, I'm trying to export data from a DataGrid to Excel using VBA, but I'm getting an error "Object doesn't support this property or method". The...
71
