Motor Condition Monitoring
Have had a couple of requests from customers for condition monitoring systems. They usually drop the idea when they hear the price :)
Instead of a permanently installed monitoring system, which will be very expensive for the sensors, the cabling and the monitoring hardware, as a cheaper alternative have a set of vibration sensor + monitor that can be installed on a for the purpose prepared measuring point (i.e. a predrilled and threaded hole in the part that has to be monitored). Then have a guy go around monthly and take manual readings.
Combine with thermographic images and you have a reasonably good preventive maintenance regime.
Our motor failures are few and far between but every time we do have a failure, it turns into this big "How can we prevent anything like this form ever happening again!!!?" situation and the then monitoring is the new panic, till the next panic comes along.. We seem to do this with many different downtime events.
Ahhh, the good old engineering/management disconnect... "what can we do to avoid this happen that doesn't involve any investment whatsoever?"
Hello all, In my facility we have multiple 3HP 460V motors that are being controlled by VFDs which drive conveyor belts. The drives are randomly...
173
18
741
Kindly, has anyone tried to control Lenze servomotors with Siemens S120 drives ? Any special hints ? Have some concerns for the resolver and servo...
178
Dear Members, Hello, we are working on a project and facing an issue with the plantpax 5 PMTR library, we have a bidirectional motor, which has 2...
185
Hi all, New here and new all round to PLC`s. We have a servo drive that runs a cross travel beam backwards and forwards. I am having trouble with...
134
