Cimplicity Workbench not reponding when trying to open an existing project file
i03oo3
Mar 2021
NJ
Hello all,
Sysadmin here in the process of deprecating an admin account and creating a new one. As part of that I was testing to make sure that I would be able to open/run an existing project in Cimplicity 8.2 under the new account and found that whenever I try to open this existing project Workbench would hang (Not Responding) and I would need to end the task.
Event viewer shows that "Application Path: C:\Windows\exe\CfgCab.exe" is the offending application. I already checked that there is no lock file present in lock folder under CimPE\Projectx\lock and I also tried logging back in as the original admin user and copying the project folder under a new name and then running that project file in workbench under the new admin and found the same issue. Everything works as expected under the original administrator account, just not in the newly created one. I did make sure to stop and close the project under the original admin account before attempting to to open it under the new one. Are there other processes that would have a lock on this project that would prevent it from running under a new user profile?
Sorry if this is basic question but I don't have much experience with Cimplicity other than making sure that the project is running and adding a point for logging here and there. Thank you in advance for any assistance you can provide.
I am guessing, but odds are that you will need to add the new user to the project. The old user is likely already in the project.
hellow in our site we are using cimplicity cascade and after we creat a new point in the workbench, all the points in point branch are disappear...
858
I'm working on some upgrades on a CIMPLICITY system. I have a project folder which includes a .gef. When I open the project in workbench it looks...
2,189
Hi all, I have inherited a quite complex control system that makes use of various PLC, proprietary and database links. The central SCADA system...
2,125
Hi everyone, i'm having a little problem recently with editing on the workbench of cimplicity 5.0 i really can't figure out where the problem is...
1,571
hello every one I have cimpicity HMI trial version , and when I try to open the project there are message appear to me as shown in attachment...
1,809
