mylespetro
Anyone have any idea how to access .ACD files that are located on a mapped network drive? I swear I used to be able to do this, but for months now, the directories show up in the Open... dialog with a ? over the drive. For example, we have a folder named ProjectFiles that I have mapped as my P: drive, but when I try to use the Open dialog, it shows up in my Quick Access, but as I mentioned, it has a ? over the icon and it just says P:\ instead of P:\ProjectFiles. When I try to open the .ACD file from one of the folders in that drive, I get an error that says "Failed to open file 'P:\XXXX - XXXX.ACD'. Path doesn't exist."
I'm just curious if I'm misremembering and I was never able to do this, or if I accidentally caused it by changing a setting somewhere.
Thanks in advance
EDIT: The error number is 717-80042016. I'm going to Google it now and see if anything comes up.
EDIT 2: An older thread popped up, but it seems to be a bit different of a problem than I'm having. In that thread, it seems that the file ended up being corrupt, however I can open the .ACD if I place it on my Desktop (or anywhere on my computer). I would rather not do that, as I don't want to be making changes to a separate copy of a program and forget to place it back in the networked project folder and cause confusion.
Thanks in advance
