I seem to remember you mentioning that you have tried Ethernet.
Some time ago I had an existing system on a Q series where the Scada driver was part of Mitsubishi badged Ifix system & they were also using MX Component for other data handling.
I was tasked with replacing the Scada to an updated IFix plus use Kepserver as the I/O driver. I found that I could not connect using TCP but found it worked a treat on UDP. I also had a work colleague who had the same problem he contacted Kepware & they said UDP was the way to go.
I have used the FX Ethernet adapter with kepware & it worked a treat even in TCP mode, As far as I can remember the setup of the adapter was simple & did not need any plc code.
