Serial Communication between Weintek HMI and Fatek PLC
khalilyousaf
Aug 2019
Pakistan
I am working to control some objects using Weintek HMI through Fatek PLC. I wrote a simple program to control an output Y_0 using input X_0. I just put a toggle button to control a led. I selected plc-fatek plc. Communication protocol is RS232. Whenever I go for online simulation, the button and led go invisible and plc shows a pop up "NO RESPONSE".
If I connect a button without any tag of plc then it appears during online simulation but when I define tag from fatek plc then this issue comes.
Kindly guide.
Kindly guide.
AOA,
Check you communication parameter and cable connection.
Best Regards,
Check device manager settings ports>com port #? then put the same com port # in your win pro ladder RS232 Settings.
Hope this will help you
Hi Experts. I need your help, I wanna communicate a MIcro850 with L19ER CompactLogix through Serial communication (Modbus RTU). I am using...
2,158
problem in communication between micrologix 1200 & Panel View 600 Plus by serial DF1 Hello Friends i have to do communication between micrologix...
6,616
Hello everyone, I want to make a serial communication using Siemens S7-1200 with CM 1241 (RS-232) and communicate with my Arduino. Here is the...
9,808
Hello. I want to establish serial communication between the S7-300 and a raspberry pi. Toward that end, I'd like to begin by sending a simple 1 or...
7,296
Hi everyone, I'm trying to go online with an IFM PLC over a serial connection, using CoDeSys. Things were working fine for a while; I managed to...
11,447
