Kinetix 300 in velocity mode (Servo.Out.ReferenceSource = 1) and drive not run
ortega
Jul 2010
Brazil, São Paulo
Hello,
I am using Kinetix 300 with CompactLogix (Ethernet IP) and it works well, but happened twice along one day the following situation: I turned on Servo_Out.DriveEn, it returned to PLC Servo.In.DriveEn = 1 and Servo.In.PowerStructureEn = 1, I put value to Servo_Out.CommandCurrentOrVelocity and the drive does not rotate (there is value to parameter 76 and 77, accel and decel for velocity mode).
I keep Servo_Out.DriveEn = 1 to control velocity, and just put 0.0 to turn off the drive. We are using safe torque off, but it is OK, because no faults are active (and Servo.In.DriveEn = 1 and Servo.In.PowerStructureEn = 1 o_O).
Can someone help me?
Best regards,
Evandro H. Ortega.
I am trying to set up a Kinetix 300-Micrologix 1100 system. I have most of the bugs worked out but I am stuck on something. I am...
2,276
Have a system that has been running for over a year and all of a sudden getting a ExcessiveVelocityFault on one of the drives when the MSO command...
138
Hello PLCS.Net Forum, First time posting. Let's assume I am a novice. BASIC PROBLEM: My servo/linear piston is no longer zeroed to the...
204
Hello. I have a few machines that use Kinetix 300 (each machine has two drives). Both drives on one of the machine keep losing IP address. They...
93
Hello, We have had a machine running for the last 10 years. It has 2 x Kinetix 300 drives. Around a year ago, one of the drives failed. We were...
420
