Ken Roach
I have an unusual application where I need to connect two large VFDs to one motor, in a "hot standby" mode where the Secondary can isolate the Primary and take over control.
If there were a 150A three-pole Form C mechanically linked break-before-make contactor on the market, that would be great. But as far as I can tell there is not.
So I'm going to propose that I install an ordinary molded case circuit breaker downstream of the Primary drive, with a shunt trip coil that allows my control system to open the breaker and isolate the Primary drive.
The Secondary drive will still have an ordinary isolating contactor so that it's not back-fed. An auxiliary contact on the circuit breaker will prevent that contactor from closing if the circuit breaker isn't tripped to isolate the Primary drive.
This circuit breaker will not perform any protective functions. The system demand is such that it's OK to go reset it by hand if it ever has to be tripped.
Am I missing anything obvious about using a circuit breaker with a shunt trip solenoid as a disconnecting means ?
