PLC code not downloading to HMI
Walks
Jun 2018
Midwest
47
I can't figure out why my studio 5000 code won't download to a physical HMI I'm testing it on. It was working before and it stopped working after I tried using a different code file.
I can see and connect to the PLC through both Studio 5000 and FT View. I can download different HMI screens to the physical HMI via FT view, I can even run the "Test application" feature in FT view and the simulated HMI works perfectly and I can actively change things in the code and have it show up on the simulated screen.
The .Mer file I uploaded to the HMI is the same one I can run in "test application" and despite me being connected to the HMI, it's like it won't recognize any uploaded code.
Hello, I am using WAGO 750-880 Controller and Codesys 2.3 to program it. I have to download the program in PLC permanently. How can I do it?
2,163
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
187
I want to set user security level based on the value of a tag in my PLC called "ActiveUser". That tag will contain the A-P code which we use for...
206
Hi All, I wanted some feedback/thoughts on code implementation or development across several offices. What has been your collaborative...
397
Hi! I'm fairly new to PLCs, and a PLC I was swapping sensors for shows the error code 497 - 0x050000 on the top of the HMI when I powered it back...
590
