New control enclosure for machine
Klincker
Jun 2018
Arkansas
So I am new here at my place of work and noticed that some of the veterans on the dayshift side are making an electrical enclosure. I took a look inside and was quite shocked with the way this was done... Should this be completely illegal to install on a plant floor or am I just over reacting. What would you NEMA rate this box also?
Maybe one more time??
I hope it worked with the attachment this time. Says its on there and then doesn't post out to the thread. If it doesn't work this time I guess i'll just have to go to the practice section lol
You know that you have to put your images in an image hosting site, right? You can’t post images from your computer.
If you did use a hosting site, it must not be allowing remote calls. Some don’t. Pick another site.
You can certainly attach images directly. They just need to be under 300kb. Maybe try resizing / compressing first.
I'm intrigued to see this image now!
We've had a number of design discussions and done some extensive testing on enclosure heating/cooling solutions for various panel builds...
680
Hello! What are your thoughts on a packaged MCC solution such as Allen-Bradley's Centerline series which can contain any combination of starter...
1,755
I am not sure why this is requested, but it was asked. Currently I have one PLC , with one output to a relay, turning on a field equipment (just...
64
I have been requested to test this proportioning valve for PLC control of flow/pressure. Dwyer Series SVP Proportioning Solenoid Valve The flow...
406
Hello Dear users, I am writing about a problem that has been bothering me for a few days, i.e. I am trying to establish remote access to the Allen...
72
