powerflex drives with or without filter
irondesk40
Jan 2008
nc
630
question.
powerflex 525 drives can be ordered with or without a filter.
I have always ordered and used the drives without the filter.
Which is really the best practice?
The filters are mostly for compliance with the tighter EU standards for EMI/RFI emissions (as opposed to the less stringent FCC regulations we have to adhere to in the US). If you are an OEM building a machine that will end up over there, you need to order them with filters. If not, no need, unless you think you have particularly sensitive / unshielded electronic equipment in your panel.
I have recently started at a new plant, and we use a lot of power flex 40 drives for conveyors. on my fiorst day they sent me to start a line...
225
Good Evening , We have a number of Powerflex 525 Drives . I took notice for years elsewhere and our plant , that our Powerflex 525 drive...
636
Greetings everyone, I know there is a way to programmatically set the date/time on a 750 series VFD (look up Rockwell automation sample code)...
1,039
Hi all, We had three drives fail upon power up. The two had F081 fault code. The maintenance personnel attempted to copy VFD parameters using a...
1,518
I have a DeltaV system that I am using to control some powerflex 755 drives over Ethernet/IP. I don't have any experience with DeltaV or any way...
783
