Ken Roach
This is slightly OT, but I figure it's something we deal with when building control panels.
Does anyone know of a top-entry, spring-clamp, miniature terminal block with a jumper option ?
My default is to use A-B 1492-J4 terminal blocks with a screw-in jumper row in the center. But I have an application that needs much smaller terminal blocks, and ideally they would use spring clamps and have the wire entry on the top.
So I'm looking for a combination of this:
With this:
I've looked through A-B, Phoenix Contact, Weidmuller, and Wago and not found what I'm looking for.
I have an application where I need about six blocks jumpered together to make a mini 24V DC power bus, with contacts on both sides. The mini spring-clamp blocks I can find are either 1-pair or 2-pair, and don't offer a jumper bus option.
Edit: To clarify, I'm looking for something very small, so 15mm DIN rail is the biggest mounting option I can use. Plate-mounting or end-brackets, or click-in posts... anything but 35mm DIN rail.
With this:
