Profibus Siemens to powerflex
729089 - PowerFlex 525 drive on Profibus DP with a Siemens S7-300 Processor
Access Level: Everyone
CM 1243-5 Manual
I don't know for sure what your setup looks like, but this tech note might help. It includes images of the PowerFlex setup and some programming examples.
Thank you for the reply, I will check that out but I believe the 300’s use the old step 7 and not the tia portal.
The 300 series are compatible with TIA Portal but check the compatibility list, I know for sure that the 319 2PN/DP IS compatible however most of the older ones are not.
Regards
Daniel
Hi All I have an Allen Bradley Powerflex 40 with a 22-COMM-P Profibus communication card. I want to communicate the drive with Siemens Step 7 but...
5,650
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
547
Kindly, we are trying to go online on an S7-300 plc, with profibus communication, using a CP5711 adapter. But when we open the Ladder and press...
780
I'm trying to figure out how to read the actual speed reference value from the move blocks, writing to a DB that is being sent to the VFD. For...
2,630
I have a piece of equipment with control split between two PLCs. A quantum 434, and a Siemens S7-300, communicating via profibus. I have a prosoft...
5,261
