Micrologix 1200 & PV600 on Devicenet
csanchez
Jan 2005
Maracaibo
Hi friends!!!
I need to see some floating values from a Micrologix 1200 in a PanelView 600. They are connected via Devicenet. The Micrologix has an DV adapter on its port "0". I don't have any scanner module on the network. I was wondering if a could get this done without adding other devices. I don´t understand how the DV adapter works and how it manages tha Micrologix 1200's data.
Thans a lot fro your help.
I could be wrong here as I've never used DN on an ML1200, but I think that the ML1200 can only be a DN slave, and that if you need a DN master you need to step up to a ML1500 and add a 1769-SDN. Check with your distributor though, as I said, I could be wrong about that.
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
642
I have a MicroLogix 1200 that has an 8 input and a 16 output. Every 6 months-year I get a fault and when online go to error it is something like...
505
Have a bad output on a Micrologix 1200. Moved wire over to an available output, changed program to associate with new output. downloaded program...
753
I need help achieving the following task: ML1200 sending 4 to 20 mA thru analog output ch0 to a DC speed controller analog input(4 to 20 mA) my...
671
Hi there I am new with this thing and i don't know how to connect Allen Bradley Micrologix 1200 PLC to Raspberry Pi using USB to RS485 in NodeRED...
2,274
