Software for one line diagrams
I use AutoCAD LT along with an Electrical Library from CadToolsOnline.com. It is only $50 for a single user library and saves me a lot of time. I have had to make a few of my own blocks but the library has most of the common blocks used in electrical drawings.
When I worked for a company without any money, I did my diagrams at www.draw.io. It's not Visio, but for free and with Google Docs integration and without having to ask IT to install it, it's pretty damn good.
I now have Visio and find it nicer to do diagrams that non-engineers will need to look at.
After comparing some of the sample one line diagrams, it seems like Visio is the software to get the style I'm after! Thanks.
I use Autocad. Someone here mentioned a while back that they use nanoCAD. There is a free version, which I downloaded a while back. It has a similar feel to Autocad. I did remove it because it changed the default for opening dwg files from Acad to Ncad, and I couldn't figure out how to change it back.
128
Dear All, Any one here use to work with PLC Moeller before? We got one old Machine need to see programming inside them. But this is first time...
1,734
I haven't needed to work with a Mitsubishi PLC until now. But I just got a call from another tech working on a customer's machine, wondering if I...
2,200
I'm a C++ programmer and I'm assigned to make an application that periodically shall comparer the online software vs the offline on a Beckhoff...
5,638
i need: 8100-HS110 Offline development software Allen Bradley 8100-HS110 | Ods Software For Imc110 does anybody have it ?
1,832
