Second Siemens HMI
RMcNaughton
Nov 2017
Dunfermline
I am wondering if anyone has set up a second siemens HMI using portal (V14) to a PLC programmed in step 7 5.5. I have attempted to do this using a proxy PLC in Portal V14 but I cannot get the HMI to communicate with the PLC. I have previously replaced an old HMI that was broken with a new one using a proxy PLC in portal and it worked fine but this was just a copy of the original. This time i want to add a totally new HMI to the system. Does anyone have any experience with this?
Code:
Many times so its possible to do. The proxy is not as good as the old tag synchronization in flexible but its still manageable.
What I've been able to do is to bring in the STEP 7 V5.5 PLC into TIA Portal, but then only use the HMI in the new TIA project, yet not download from TIA Portal to the PLC. This means, however, if you add new variables to the PLC in V5.5, you have to do the same in TIA Portal.
The proxy usually works great, we have been doing it this way for years.
You mention 2nd HMI, what was your 1st programmed in? I have never run into trouble converting older Siemens screens to TIA. Even the protool ones, it takes a couple more steps, but it is definitely possible.
How do you communicate with the PLC? Might there be an issue with addresses or something?
I am wondering if anyone has set up a second siemens HMI using portal (V14) to a PLC programmed in step 7 5.5. I have attempted to do this using a...
2,509
Hi This is about making another wired LAN connection configuration. Ya know when you go to control panel/Network and Internet/network and Sharing...
25
8,980
Hello everyone. On December 17th, I submitted a pdf (zipped) file of a program using Siemens S7-224. Has anyone taken on the task of looking at...
6,754
Hello all I have the opportunity to buy some second hand unused components, they are Siemens motor modules, a CPU, inputs and outputs. I have...
2,117
Hello all. I have a 1769-L16 that I inserted a 1769-L35E into. I was expecting it to create module defined tags automatically in my controller...
1,792
