PLC and database
BartPeters88
Feb 2015
Asten
18
Hey there!
I'm working with Tia Portal V11, a PLC(s7-1200 CPU1215) and the webserver. I also need to log some information in the database. Sadly the webserver of the PLC isn't working with PHP, this is the programming language you use to get information from your website and insert them in a database.
So my question is: How do you log your information and set them in a database without using PHP.
Regards,
Bart
A lot of PLCs have database functions that will interface directly to an SQL server rather than trying to do SQL commands with php on the webserver.
I just looked it up and Tia Portal is a Siemens product, making everything in your question Siemens related, you should put that in the title to get better information (and probably call Siemens support).
I was wondering if anyone had an success finding a Database driven managment program that can save&print all the following...
2,264
Hello, For my general information and knowledge, how is querying and storing data from a AB PLC (Compact or Control Logix) typically...
7,355
Hello Eveyone, I need your advice on one problem.I am using CompactLogix PLC.I am looking for some ways.So, that a PLC program can read data from...
26
13,224
Help will be Rewarded in the future I promise Good evening everyone I 'm working on a personal project, hope someone would be so kind and could...
3,407
Hello All This is my first Transaction Manager project. I have a working configuration in Transaction Manager 10.20 that successfully writes...
7,622
