I need help with Q Series Mitsubishi PLC programming functions
Oct 2004
I am replacing old F-series (F2) Mistubishi PLC's with new Q series PLC's, and in the process of doing so I have to convert the F series ladder (programmed in Medoc) to the Q series ladder (in GPPW)
I am having a problem with the shift function.
In the F series ladder logic, shift was denoted by [SFT M100] (doesn't have to be m100) and then on the rung below that a special relay M572 was used. I looked up what M572 is and it is called a "Zero Flag"
Here is the dilemma. I can't seem to get the shift function to work in Q-series logic...I need an equivalent to the "Zero Flag" but there isn't a relay in Q series called zero flag....
Just wondering if anyone knows how to properly use the shift function in Q series, or if anyone knows of an equivalent "Zero Flag"
come onnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn answer me someone....................................
Hi, I don't have any formal education background with PLC. I am learning PLC by myself. I have CJ2M CPU34 unit and CJ1W-DA021 unit. I would...
1,232
Hi everybody I am using a servo which model is MR-J3-10B (GA). Now I have an alarm code 96(home position setting warning). How can i fix it?Please...
1,555
What does mean by the following instructions? DP.SFCS H3E1 K1 DP.SFCS H3E1 K2 DP.SFCS H3E1 K3 DP.SFCS H3E1 K4 DP.SFCS H3E1 K10 DP.SFCS H3E1 K20...
1,839
Hi I have a problem when using the (proficy machine edition) Please help me When I click on "upload form controller" This message appears: "The...
3,041
This is an older system. My supervisor managed to let the magic smoke out of two of the comm boards in the ServoDrive controller, after replacing...
1,333
