Changing Indramat control section
jcraft
Dec 2006
Niagara falls
91
I was wondering if anyone here has ever changed out a control section in one of the indramat servo drives. We have a machine that has an MLC unit that controls 5 Indramat drive axis and it seems that one of the axis control sections has failed and a new one is enroute. Never changed one before and I am assuming we need to upload all the info from the drive before installing. If anyone has done this before please let me know the basic steps how to do this. We will be using Ingdraworks and going in through the MLC as opposed to using the MMC card slot on the front of the control section. Thanks for the help.
I don't know the MLC, so this might not be too much help.
On the IndraDrive (and even DIAX0x) units, the drive parameters are stored in an external memory card...MMC for IndraDrive, PCMCIA on Diax0x. Unless someone has modified the factory settings, all the drive parameters should be in there.
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
228
Hi all, I am having an issue where some of my HMI push Buttons and Indicators go in to error when I navigate to a new screen. I am using a...
452
We have a new machine that uses an armor block to transfer input signals for conveyor position that continuously alarms out on no position change...
85
Hello everyone, I am trying to change the IP address of the Omron PLC (NJ30-1200) and HMI (NB7W-TW01B) to fetch the network on our network...
283
Dear Experts, I'm just started working with GEO SCADA and I need your valuable help. Currently, I'm trying to edit the alarm limits on MIMIC...
207
