MicroLogix 1400 and MicroLogix Program Download Utility
Jan 2011
Vancouver, WA
I'm currently trying download to a MicroLogix 1400 PLC, without any purchased software.
I found the MicroLogix Program Download Utility from the Rockwell website, however I receive an error: "dtl32.dll was not found."
I'm assuming this is because I don't have a copy of RSLinx installed.
I'm currently downloading the "light" copy, but the description says it will only work for with MicroLogix 1100.
Anybody have any advice?
If that is a correct assumption, then you can prove it by downloading and installing RSLinx Lite.
RSlogix500 Micro Starter Lite will only work with files for the Micrologix 1000 and 1100.
Go here to the 3rd download to get RSLinx Lite.
http://www.ab.com/linked/programmablecontrol/plc/micrologix/downloads.html
Out of curiosity, I downloaded the utility and since there wasn't any separate help file to read, I went ahead and installed it and tried it out. It worked fine with a ML1500 LRP, so I would expect it works with any micrologix as long as RSLinx is installed.
Thanks for the quick replies.
Also, I was unclear, I'm currently downloading the lite version of RSLinx.
Of course, it's taking forever.
Will update if it works. Crossing my fingers.
86
Hi, I am working with a Micrologix 1400 model 1766-L32BXB. With no input wires connected to the “in12” thru “in19”, I am getting 24 volts while...
221
Hi everyone, I hope I don't butcher this up, please feel free to critique me wherever if I do, I have an issue I would equate to "chasing...
300
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
627
I'm not super familiar with the Micrologix line of processors, but I am pretty familiar with RSLogix 500. I'm trying to simply copy a string to...
302
