PowerFlex 525 Auto MDIX ENET Port Capability
aiki202
Aug 2007
Pennsylvania
178
Does anyone know if the PowerFlex 525 embedded EtherNet/IP network adapter port offers 'Auto MDIX' (aka auto crossover aka auto switching) capability?
I know I can connect directly to drive with laptop with a standard patch cable... but is it the laptop or drive providing this function?
The laptop... that is what I would think as well. Although the laptop certainly has this capability I was curious about the drive side. I reached out to RA Tech Support and according to them the PF525 drive does has Auto MDIX capability as well (so does the PF750 series drives).
Just as a test I connected two PF525 drives to each other via the embedded ENET ports. Each has a unique assignment on the same subnet. I used a standard straight through patch cable... according to the drives ENET LEDs and parameter F683 there is an active connection between the devices (although no Tx or Rx... nothing telling them to talk to each other... but they can see each other)... seems to confirm what tech support is telling me as well.
I am trying to wire a 525 vfd for a Hand/Off/Auto setup. Hand is a manuel start cmd (T 11 to T 2). Auto will be over ethernet. I am not for sure...
4,277
218
Im trying to teach a couple of labs on VFDs at a community college. We have some motor control trainers with P525s and 3 phase motors from...
224
New to vfds. I put in parameters. IP, but I get ethernet flashing and link solid. What did I do wrong?
456
Are the N files in the 525 the same as the 40p for ethernet? (E-Comm card) I have used 40P with Micrologix 1400 Messaging but don't see the N...
221
