Questions about Magnetization Current in Induction Motor
bodoo23
Jan 2018
Athens
57
I can not understant two points about magnetization current in induction motors.
1-It is said magnetization current is almost constant in induction motors. I can understand that if we run motor in v/f scalar mode or directly by contactor. But if we use vector control , as you know v/f ratio changes according to need. So According to my understanding, magnetization current also should change when we are running in vector control mode. What do you think about it ? (Do not consider field weakining point, My question is for any point under field weakining)
2- I have a 1PH8 motor that I used in a project. In manual of motor it says magnetization current 215A but when I calculate magnetization current from motor nameplate (Motor rated current = 460A and P.F = 0.85), I found about 240 A. What is the reason of this difference ? They should not be the same ?
Thanks in advance.
There are others here who know more about this than I do but your post has gone unanswered, so I will tell you what I believe to be true.
Thanks in advance.
1. As you said the magnetizing or flux current for standard motors remains relatively constant. My understanding is that any control method (v/f, FV, SV etc.) gets "layered" on top of the flux current to control the motor.
As an example: Assume you have an uncoupled motor. Once the VFD has established the flux current it then can hold the motor at zero speed with only the flux current. Any extra current is only needed to move or hold a load.
2. The flux current for any motor can be calculated based on the nameplate data, but those calculations make a lot of general assumptions and can only get you in the ballpark of the true flux current. If the flux current is listed on the nameplate that means that the manufacture has taken the time to test that particular motor design and give you the true flux current requirement.
I hope this helps answer your questions. And if anybody sees something I've written here is wrong, please feel free to correct me.
I assume that this is one of the things a VFD is checking when you do an autotune procedure on it?
Hello, My background is IT, and I have very little (effectively zero) understanding of PLCs. I have been tasked with acquiring version 2 of...
80
Hi- I am configuring an alarm and event server to display 1 current alarm at a time on a big display. Having a few issues The alarm doesn't...
54
Hello everyone, I'm new here. First of all I just want to say that you guys are very knowledgeable and reading your posts on here has saved my...
162
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
259
Hello, I am new to Codesys, and am trying to learn about it for a project we're developing. I've got a couple questions, but first a little...
142
