What is the best way to clean Ethernet connectors?
EJSControls
Apr 2020
Conover, NC
20
Hi all,
The plant I work in seems to have a lot of contamination that affects our Ethernet connectors on all of our control panels.
We are constantly losing communication to drives and PLC's at random times. The technicians are simply wiggling the cables or unplugging and plugging them back in to get things back up.
What are the best things you found to clean the jacks and plugs?
Electrical contact cleaner and a fine brush.
A soft wire brush preferred when the other end of the cable is not plugged in.
A plastic toothbrush when the other end of the cable is probably plugged in.
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
485
I have S7 1512C controler for controlling 48 PID temperature loop, the output is PWM. Please I need the best, most efficient way to write the...
600
I am going to need to use HART multi-drop in order to handle a series of Vega Radar units. There are a lot of options and I'm wondering what...
253
Out of interest, I'd like some thoughts on what would be considered best practice with regards to a 2-position turntable control scheme (see...
17
1,134
Hello colleagues Anybody knows, what could be the best or a better option to bring with you when you are in service at factory to connect via...
261
