I have a weird issue with a ControlLogix processor and was wondering if anyone else has had the following issue. There is a PLC-5 which communicates to the ControlLogix via DH+ using a MSG instruction. This has been working without issue for over 7 years. However, recently it was noticed that the area which was being written to by the PLC-5 was being overwritten with other data! The code in both PLCs had not changed and all other PLCs on the network were checked and confirmed that no other PLC was writing to the ControlLogix, the only other machine that was connected was an upper system (SCADA) but also was not writing to the area in question either.
Eventually ControlLogix was powered down and on powering back up the issue had gone away! Going to program mode and removing the DH+ cable had failed to clear the issue. This is the second time it has happened to us with a ControlLogix processor (not the same one!). I don't have the type of processor or firmware version to hand but can get them tomorrow if required.
Steve
Steve
