Comm issue between Micrologix 1200 and PanelView 600
edwinmart
Jun 2006
Santo Domingo
31
- PanelView 600 2711-T6C16L1
- Micrologx 1200 Bul 1762 Series C (1 Com Port)
- 1761-CBL-PM02 Serie C (Cable)
I can connect to the PLC using the cable. And I can connect to the PanelView using a RS232 Cable. Even selecting the same RSLogix DF1 connection on the PC.
The Network Configuration is:
Micrologix
Node 1, DF1 Full Duplex terminal
PanelView
On the Panelview I did the communication setup creating the Node of the Micrologix, using the name of the PLC in this case "2421RTA" and node address 1, on node type I selected "MicroLogix"
Node: 2, and is a DF1 terminal.
Baud Rate: 19200
Use Networking: Selected
Parity/Stop Bits: None/1
Error Detect: CRC
Handshake: Off
But I always get the message on the PanelView: that the "Panelview Offline".
I dont know what I am missing.
Edwin
Is the cable you mentioned the one you used to between the 1200 and the PV? If so that is the wrong cable, you need the 2711-NC21 cable for comms. between the 1200 and PV.
you can use the 1761 CBLPM02 with a null connector. Few months back I had the same problem. I used 1761CBLPM02 with a home made null connector. I used two 9 pin plugs and inter-connect pins. I had to cross 2 pins. I am trying to dig out the pin out for it.
thanks for the help
Thanks guys for your answers. Im gonna try to get that cable. I am outside of the US for that reason sometimes is easier for my to build my own cables using the pin out, so Ranjith if you have it I will really appreciated.
Hi everyone, curious if anyone has ever witnessed the following comm error: A little history, I had a department PC die, WIN 7. Had to upgrade...
623
Okay so I just went into my ML1500 and mistakenly changed a comm setting for channel 0 or 1 channel config section of the programming software...
1,173
Hello All, I was recently tasked with updating the firmware on all our Micrologix 1100s to v16. I took processors from the bench, flashed them...
2,648
We have a 176 ton press that I want to pull the program off of the FATEK PLC. I have been dealing almost exclusively with Allen Bradley and am...
2,751
I have a 90-30 plc and a Cutler Hammer Panelmate for HMI. The backplane was replaced due to erratic connection of PS (it is 90-30 with CPU in...
3,421
