78725 Member 7 Join Date Oct 2013 Location Dodge Center Posts 5 Nov 21, 2013 #1 I am having problems with my branch outputs both turning on it will only turn on one output that is output 4? not sure what I am doing wrong. I:0/2 O:0/1 { }------------------------( )------------ |____( )____| O:0/4
OZEE Member O Join Date Mar 2006 Location Kansas Posts 1,696 Nov 21, 2013 #2 Is there something else later in the program that is also addressing O:0/1?
78725 Member OP 7 Join Date Oct 2013 Location Dodge Center Posts 5 Nov 21, 2013 #3 It does not matter what I title the output it will still only activate output 4.
bernie_carlton Lifetime Supporting Member + Moderator Join Date Apr 2002 Location Yakima, Washington Posts 6,413 Nov 21, 2013 #4 It may be possible that output 4 is being turned on by some other logic and this rung is not being activated at all. If you can, zip and post the program.
