plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old May 20th, 2010, 08:46 PM   #1
tm_0405
Canada
tm_0405 is offline
Question Communication Question, please help.
I have one CJ2H-EIP21 PLC with an ethernet hub connected with some devices. There is another CJ1 PLC with ETN21 module also with a hub connected with some devices. Now I need to set up communication between these two PLCs. These two PLCs have difference IP address. what is the best way for hardware? Will I need a router in between? Can I just use a ethernet cable plug to both sides of the hubs? What is the best way for software? Will I have to use FINS communication? Will I need to set up routing table? THX
Old May 20th, 2010, 08:52 PM   #2
diat150
United States
diat150 is offline
post the ip, subnet and gateway for each plc. if they are in the same range then you can use a cable to connect them. if they arent I would put them in the same range if possible.
Old May 20th, 2010, 08:58 PM   #3
tm_0405
Canada
tm_0405 is offline
Thanks diat150, Because they are both kind of alone, Can I set up both same as 192.168.0,1, subnect 255.255.255.0? So you mean I can just plug cale to hubs? what about software? FINS is the only method? THX.
Old May 21st, 2010, 01:58 AM   #4
ArikBY
Israel
ArikBY is offline
ArikBY's Avatar
If you can set both IPs like (1)192.168.0.1,(2)192.168.0.2.
From that point it is easy
You will need routing table for both of them with the same network No.
If you can set the IPs I can send you working sample.
__________________
Arik
Barak Control Israel
Old May 21st, 2010, 12:25 PM   #5
tm_0405
Canada
tm_0405 is offline
Arik, thanks, I'll set IPs as that, please you could send your sample,THX.
Old May 21st, 2010, 05:56 PM   #6
ArikBY
Israel
ArikBY is offline
ArikBY's Avatar
I send you 2 projects
Your lucky I document my projects in English.
Pay attention both set to network 10
You need to use routing table(not Attached)
I use to read not to write when I deal with communication .So both of the PLCs just read from the remote PLC.
Feel free to ask if you have any question.
__________________
Arik
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
SLC 5/03 Communication question clueless_one LIVE PLC Questions And Answers 4 June 11th, 2009 01:46 PM
A mitsubishi communication question here tommee10533 LIVE PLC Questions And Answers 5 August 18th, 2008 09:03 AM
OPC Communication ikon2018 LIVE PLC Questions And Answers 0 June 21st, 2005 07:47 AM
AD PLC communication question BoxerBrats LIVE PLC Questions And Answers 2 June 6th, 2005 08:36 AM
AI2 software for PLC2 - online communication question Contr_Conn LIVE PLC Questions And Answers 7 November 10th, 2003 05:58 AM
