modbus communication b/w wago RS232 module and Automation direct HMI
Siby
Jul 2006
Dubai
27
Dear All
if any body can help me in establishing communication B/w WAGO RS232 module and automation direct
My Controller is 750-841
and RS232 module is 750-650
i have tried alot but couldnt succeed.
IF any body can send me sample program for the same..
Regards
Are you unable to send/recieve data via the rs232 module or is your problem solely with communicating with Automation Direct?
If you are unable to send/recieve data (to anything) I may be able to help.
Let us know more details please,
Iain
A bit more information is going to be needed. AutomationDirect has several different versions of HMI's.
What HMI are you specifcally using?
What protocol are you trying to use? (MODBUS, MODBUS TCP/IP, ???)
What communication method are you using? (Serial, Ethernet, Etc)
Hi, I've been struggling with this for the past two weeks now. As part of a bigger school project, I've been tasked with setting up several...
3,804
I have 2 Wago Processors(750-842) and i am trying to Communicate between them through the Ethernet. I am using the function block Ethernet modbus...
5,485
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
343
Apologies for not being the best IDEC programmer. I recently was doing some inspections on a site that had 3 FC6A IDEC processors. The issue is...
115
Hi all I need help on this As in my project used Schneider TM241 controller. Now I want to communicate Elite energy meter with controller by...
192
