jthornton
I have a 1768-M04E Sercos module that in the Module Info tab for configured it says no. I have RSLogix 5000. How do you configure the Sercos module?
When I open a drive and click on the Module Info tab I get an error the module can not be found the path specified is invalid.
On the Sercos module the cp led blinks red/green and the other two blink green. The Sercos document states:
Did you configure the module?
•NO — Use RSLogix 5000 software to configure the module.
•YES — Check the configuration of the module and drives in RSLogix 5000 software.
Edit: the drives are Kinetix 2000
JT
JT
