How fast do the tags update in factory talk View SE
sunnyvaleplc
Sep 2009
sunnyvale
I have a fast analog Input, that changes every 100ms or so, and i want to display that on the Touchpanel (PV1000 -Compact series). I am using the Factory talk View SE edition. How can I change the TAG update rate inside the Facotry talk View SE or the Touchpanel itself to be able to display the 100ms analog value.
Right now, the value is jumping a lot, cause the display is far too slow.
Thanks,
plcguy
Right Click the Display and select Display Setting. In the lower left-hand corner you will see were you can select the Max Tag Update Rate.
HTH
Task Description: Currently I am working on a program in C # for reading data from RSLogix5000 Series controllers (v18.11). The idea is to do...
36
18,385
Hey everybody. New to working with PLCs as I just got a new job out of school. Using Factory Talk SE. I am creating the HMI screens for our line...
1,659
Hi All, I've been playing with 2 stratix switches in my test bench and seeing how different configurations affect the behaviour when 2 managed...
226
Dear all, Im using Allen Bradley Compact Logix L36ERM as a PLC. and facing a problem where I need to create a FIFO buffer that fills an...
1,658
Dear Members; We have Fluke 754 hart communicator. We have wired up three transmitters of Rosemount Model C3051 with this input module. But when...
1,848
