MODBUS RTU TIA V 13 Logging Pressure from Pressure sensor
qwemx
Jul 2017
Earth
195
I have siemenns S7-1200 cpu and TIA V13
i have to create a apparatus which will be used to monitor pressure inside some test enclosures
it should monitor the pressure and transfer it to a data block
every 15 seconds it should record the presure and save it as a chart
i also have to select a pressure sensor i found one on the web which speaks Modbus RTU
i want to communicate with this sensor and record the log of pressure , if there is leakage the test is failed , if the pressure is stable and there is no leakage the enclosure will pass
Hello
Is it possible to Make a modbus program on PLC and then connect this PLC to my laptop via an ethernet cable and try to simulate the Logging by using some application on the laptop which will send data like the sensor does .
There are a couple of ways to simulate a Modbus TCP Server.
You could use a PLC simulator like the Do-More Designer software.
https://www.automationdirect.com/do-more/brx/software/simulator
This is a free programming and simulation package that includes drivers for Modbus RTU and TCP both Client and Server (Master and Slave)
Here is the download link:
http://support.automationdirect.com/products/domore.html
The other option is to use EasyModbus.
https://sourceforge.net/projects/easymodbustcp/
This free package can be used to set up a Modbus TCP Server. I believe a sample program is already included in the package.
Here is a thread that combines both of these packages together.
http://accautomation.ca/modbus-tcp-data-logging-to-database/
Regards,
I'm trying to communicate with a heating controller over Modbus RTU (RS485) but I'm running into the common issue of having no Rx light. S7-1200...
4,039
Hi! I communicate with an onboard communications board modbus RTU. I communicate with 5 VFDs (Parker AC10) and each has 4 calls of MB_Master. So...
19
8,062
Hi there, I'm using an S7-1200 system and I have followed a Siemens application example to read/write data to 1x slave using Modbus RTU and a...
4,178
Hi All. Could you please help me with this Modbus I've been trying to set up for the last 10 weeks!!! I have an VIPA CPU314SC and trying to...
2,054
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
46
