analog flexI/O to VFD
jcole28
Jan 2018
Kentucky
View attachment vfdvfd.pdf
The attached files shows analog terminations from flex I/O modules to VFD. I have someone telling me that I should use isolated cards instead of nonisolated cards. I don't see any possibility of noise or ground loops. Why else would I use isolated over nonisolated? Am I missing something? Do you see a problem with the terminations? I am not familiar with flex I/O but it doesn't seem any different than any other analog modules that I have installed. There are also three 4-20mA devices connected to analog input card. The VFD is a 0-10v input. I don't see this being a reason to isolate though.
Good afternoon, I am currently working with an HMI/PLC LP-a070 and I require at least one analog output, but the PLC does not have one. I was...
104
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
110
I'm having trouble calming down 2 Tempo Sonics. I'm using Studio 5000 CompactLogix my Raw value is jumping around from 8575.0 to 8755.0 at a...
30
1,127
257
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
118
