Powerflex 753 2262D-2R I/O
mylespetro
Dec 2015
NS
740
Hey everyone,
Ran into something strange today, we have a drive with a 2262D-2R I/O module in port 4, and we were checking the digital I/O and we were experiencing anomalies with a N.O. fault reset button. We weren't getting any inputs in the Digital In Sts screen when we pushed it, so we measured voltage across and it was reading 0.5V when it was not pushed (open) and measured 120VAC when we pushed it (closed). We pulled the wire off of the drive side of the button, and we can physically see it going into the Di4 terminal. We measured it to ground and we were getting 120VAC coming out of Di4. Is there some kind of parameter or jumper that would cause this? I've never seen anything happen like that before. My first though was some kind of sinking/sourcing setting, but I can't seem to find that anywhere.
Thanks in advance.
Disregard, was an easy fix. After thinking about it for a second I thought the Di Common might not be wired to neutral so I ran out to check in the field and that was the case.
Hi, I am setting up a powerflex 753 using connected components workbench. On the option module you have the relay outputs at the bottom of the...
1,861
How to remove faceplate from power flex 753 and not shutting the system down. What parameters should i change?
73
Hi all, I am having a problem with a powerflex 753 we have on site and keep getting input phase loss. The drive has been running for a long...
1,267
Hello Friends, We have a powerflex that stopped working sometime last week. It doesn't communicate over the network, or use CCW directly from my...
403
Hello all! I am fairly new to the world of PLC's and this forum, so I apologize for my lack of knowledge. I have a Powerflex 753 that keeps...
491
